MJPeabody88
MJPeabody88's Achievements
  1. Just replaced my pump w/reservoir (reman) and pulley. Removed my PS mount and brackets. Took a wire wheel to them and painted for a nice clean look. Haven’t lifted it yet. Don’t plan on doing any off roading to need better response. I would go for an aftermarket pump and mounts. Looked into it but I just want to get her rode ready so I can enjoy her for a bit before going all out on a build.
  2. This is my first Jeep. Just did the water pump, thermostat/ housing, power steering pump, and a ton of cleaning. Only the steering pump assembly was necessary. Did everything else for the hell of it. Took my time and after dealing with being given the wrong parts, finally got everything back together. I have a closed system, went through the bleeding process, and couldn’t get it right. Kicking myself for not drilling holes in thermostat. I didn’t fill the radiator through the upper hose, or into the stat housing. I think I have my water pump outlet and heater hose backwards. Just going through the paces of trial and error. (Noob). Started raining. Going to mess with it tomorrow
  3. Replacing the thermostat housing, water pump, power steering pump, and timing assembly. Need the torque rating and any kind of info. Thanks
  4. Sorry didn’t see your comment but it’s a thin layer of grim. No huge chunks. Thought of introducing a little seafoam at a time. I always start the truck and let it run a few times a week. Drop the oil and change it periodically as intended. Worse comes to worse, I plan on Getting a good donor Cherokee with a fresher motor and drivetrain
  5. Anyone from the 757 area!?!???? I’m reining from Smithfield
  6. She may break em off though. Definitely a daddy’s girl
  7. Any help is greatly appreciate!!! Figured 7-12 would be a good range of play. So used to work on my Diesel engine. Easy to over tighten without a torque wrench. Might as well get my daughter to tighten them for me. Hahaha!!!!
  8. Gave the valve cover a good 2 + hour scrubbing. The oil residue was terrible!!! Shes definitely going to get some well deserved attention. I did notice It didn’t take much to loosen the bolts to the valve cover. Half a turn then loosened by hand.
  9. Under the valve cover looks pretty grimy. Would running seafoam in the oil take care of cleaning up the gunk or is there another option you’ve had good results with?
  10. First time ever wrenching on a Jeep. Even though it’s something as simple as a new valve cover gasket, I’m smiling from ear to ear. Even while fighting the bolt closest to the firewall. This Comanche is my first Jeep I’ve ever owned. Now, I’m hooked. Love the platform. Everything about it is awesome and to have gotten lucky on one in such condition makes it even better. Restoration is super slight. Looking under the truck I found only one spot of rust on the bottom floor pan the size of a baby’s fist. Gosh I’m so freakin excited to work on this thing. Can’t wait to go out in the ocean to go scalloping. I’m going to order a crap ton of parts and buy a donor for the 4x4 swap. Glad to be apart of a forum with great advice and other members who understand that your a noob and don’t knock you down about it.
  11. Is this resistor absolutely a must have or can you simply run a jumper?
  12. Thank you thank you!! She’s in great condition to have 266k on the clock. Really looking forward to adding some goodies over the summer
  13. I will surely check it out. This is my first Jeep so everything is a learning curve. Thanks for the tip here's a pic of my Comanche
  14. Great write up!! Was considering a diesel swap for the 88 mj. After reading more and more, just seems to be a lot. I guess I’ll just stay with the 4.0
