cquinnball
Everything posted by cquinnball
  1. Yes, it is there. Just trying to find the body kit and grill. I am going to restore it back the right way. Thank you, Cameron
  2. Just wanted to get this highlighted again. The kit is for an original street comanche that I will be restoring. I am hoping someone is willing to sell the body kit and grill. Thank you!
  3. No. Not yet.
  4. What town are you located in eastern NC? I have an 89 long bed pioneer also. Thank you!
  5. That is what I’m looking for. If you can wait until spring I can too. Pete, you’ve been to my place to drop off a bed. Would you be heading to the northeast?
  6. I was able to get my hands on a Street Comanche for the project but it is missing the kit and front grill. If anyone has a body kit or grill for sale I would be very appreciative. I have located a few but none are for sale at the moment. I am located in NY. Thank you!
  7. I am looking for a LWB Comanche specific fiberglass bed topper. I have seen a lot of posts about S10s fitting but being a little short at the cab. Trying to get a Comanche specific topper so I don’t have to deal with the fit issues. located in NY but willing to travel within reason. thank you!
  8. Forgive the stupid question, does a 97-01 hood fit a Comanche without replacing the fenders or header? Thank you.
  9. I am on Long Island, New York.
  10. Hello everyone, I am looking for as close to mint of a tailgate as I can find. I am also looking for courtesy lights, manual black side view mirrors. I am located in 11782. Thank you!
  11. Thank you for this. I will have to see what headlights are in the panels and buy the proper size. I am an accountant, so math clicks with me. Thank you again!
  12. Hi Thanks for the feedback. The lights are for conversation pieces, not functionality. I just don't want to blow out perfectly good headlights so i may try with a light bulb first and covers like you suggested.
  13. I was planning to use the stock headlamps. Will those not work with this driver?
  14. I will try this! Thank you. Once I get it done I will post on this thread. Thank you again!!
  15. This was for the back wall of a garage. I have quite a few header panels with stock headlights, I would like to set up on to a single switch. I am just not sure of exactly how to set it up. So if I use the driver on the link i sent to you would i just continue the regular house electrical wire to the headlights? Or do I need to use a different wire after the driver?
  16. please forgive my lack of electrical experience. So if i have standard wire in my garage that has an existing switch and light bulbs could i install a junction box and run it to a switch and from the switch to the headlights i would use the below coupled with what fuse? Sorry again, and thank you! https://www.amazon.com/gp/product/B07MDFK9JP/ref=ox_sc_act_title_1?smid=A2S7ZIGVI25YZ9&psc=1
  17. Thank you! I will have to google all of this but i am sure i can work through it.
  18. Hi, Does anyone have a header panel with headlights connected to a light switch in their man cave or garage? I am not sure if it is possible and I am not much of an electrician. If you do would you mind sharing a picture?
  19. Okay. I will start there. Thank you!
  20. Its small, maybe about two to three inches up and about the length of the top portion of the well. There is definitely some filler in there that i want to remove with clean metal.
  21. I have read that good way to patch bedside fenders is to use a patch from a 2dr xj. Has anyone had any experience with this? Does using the rear fenders of a 97+ 2dr work to patch rear wheel well rot? Or just pre 97? I know someone parting out a 97+ 2dr. Thank you!
  22. Does using the rear fenders of a 97+ 2dr work to patch rear wheel well rot? Or just pre 97? I know someone parting out a 97+ 2dr. Thank you!
  23. Thank you! That’s what I’ll do. Does a combination of a BA10 with a NP231 put the shifters in different locations than an AX15 and a 231? As of now it seems as though a full size console does not fit over the shifter and 4x4 shifter properly. I was thinking of swapping in my ax15 and 231 now.
  24. Maybe this one is better?
  25. I have a 1989 Comanche that was converted from a 2WD auto to 4WD 4x4 and the PO cut a much larger hole in the floor than needed likely to make it easier for themselves. As we know, that makes things more difficult for the new owner. I am looking to build up from the top of a BA10/5 to fit into a full size console. I do have an AX15 as well and plan to switch to it one day. Would someone be able to help me with what parts are needed and if I will have to buy them used or if i can get them new meant for another model Jeep? I added a picture below so you can see the hole. I think i need an inner boot, shifter floor plate, bezel, and outer boot. But i am not sure what is compatible in terms of parts from other models. I really hoping to find the correct shifter floor plate to see if i need to weld any remaining holes. The goal is to fit the 4x4 shifter and the manual shifter into a full size console. Thank you in advance!
