ratty
Everything posted by ratty
  1. Thanks for your help. I appreciate it
  2. I found it! It was a tiny crack in a grey vacuum hose that goes into the firewall. Crazy
  3. Seems like all my hoses are fine. I think it might be behind the dash now. Maybe my vent doors are stuck or the controls aren’t working.
  4. This is great! Thank you
  5. Good to know. The idle is great
  6. Ok cool. Where would I find the hoses for all of that?
  7. Hey again. My air vent stopped working. It also doesn’t work on heat or ac. It does work on defrost. Thanks in advance.
  8. Handle moves. Right latch is working but the left side isn’t. Unscrewed the handle and both rods are still in (#7 on the diagram). I’m thinking one of them came off on the latch side.
  9. Everything looks like it should. I’m stumped
  10. I haven’t had time too fully look but I’m assuming they both came loose
  11. Awesome. Thanks for the diagram.
  12. Just like the title says. Went to open the tailgate today and the handle went all the forward and won’t open now. Is it as simple as pulling it apart and figuring it out? Thanks.
  13. Sounds like a future project for me.
  14. Everything is connected, unless I didn't connect the hoses in the right order on the tcase. Is that a possibility? It's the photo I posted.
  15. Everything looks good underneath. I have no idea how this happened
  16. What controls it?
  17. Tried my truck in 4H and 4L. Won't go anywhere in 4L and could barely turn around in 2.
  18. ratty
    1JTMP65PXJT074658
    It's all good
  19. ratty
    1JTMP65PXJT074658
    I posted this a long time ago haha. I already did an engine rebuild.
  20. Hello. I was swapping out my speedometer cable and accidentally pulled all those colorful vacuum lines out of my transfer case. I put them back in and now I have a light on my cluster that says "part time" and when I make a right turn there is a horrible crunching sound. Is there an order to what color goes where? What did I do?
  21. Good to know. Thanks!
  22. Yeah! But I'm pretty sure that just started
  23. Like it says. Can't seem to find it. It's pretty constant. I can hear it the loudest when my foot is off the throttle and cruising. IMG_7181.mov IMG_7177.mov IMG_7180.mov
  24. Weird. Started taking the arm rest off and it unlocked ¯\_(ツ)_/¯. Always something with this truck
  25. Great start to my morning. Had to climb in through the passengers side. Like the title says, can’t unlock my truck. With the key or from the inside.
