comancheel
Everything posted by comancheel
  1. I am doing a chevy 350 swap with a ax15 into my 86 longbox. I was going to use zj springs and spacers for a few inches of lift. I figured they held up a v8 so Th ey should be fine. But was recently told that they may not be enough to.hold the weight. Any info or comments would be greatly appreciated as I'd like my truck to be proper.
  2. What year of zr2 springs? And does it matter if it's crewcab or not? I've been searching for a alternative to add a leaf. Or spacer lifts for a long time. I found a set of zr2 springs, brand new for 200 each Canadian. The spring company says they are same width at 2.5inch but about a inch shorter. I'm hoping with these shackles I got that it won't matter. Also was gonna do a axle flip for lots of lift :) Any body have any luck, good or bad doin something like this? Also havnt figured out the front yet. I was originally gonna just axle flip and go zj springs with spacers till.i seen this thread. Now.i have hope.i.can go bigger in the front and not have a $#!&ty rear lift tryin gn to keep rideheight. The truck is pretty stock still. I'm stockpiling parts for a sb350 swap.mating to the ax15. Almost got.everything except a clutch
  3. Hi everyone. I found this truck sitting in a back alley that I just moved to and talked the guy into selling it for 750. It sat for two years he said front end and clutch was done prior. He put new 235 75 15 and a battery after i talked to him. Not sure how crazy I'm gonna get but just wanted to post some pics and some ideas and get some feed back. I'm new to Comanche's. I'm pretty stoked about doing it up. I'm a thrifty builder so any cheap mods or custom lift ideas, 'get rid of the 2.5 and stroke a 4.0 liter' kind of ideas. Right now. I'm getting it rust free, mechanically sound. It'll be in a constant state of repairs and upgrades and I'm looking g forward to it. I'm going to paint it dark blue and grey. I'll show you what I've done and get some more pics up of some more recent stuff. I've got about 30 hrs in getting rid of all the rust. Ive got rid of everything from the front to the back of the cab. Planning to remove the box turn it upside down and sandblast it and see what's left. The bed is good but the rear quarters bottoms and around the tail lights is pretty bad. Drivers side floor pan was the worst. I split the top layer of the subframe off and saved the bottom . Cut out the tin from about just passed the pedals to the back of the cab. Replaced it with checker plate for the drivers floor. And rectangular tubing that fit perfectly inside the bottom subframe. A d slightly thicker tin in the back. Passengers side was much better shape but not perfect. Had to patch a few spots. Going to do the checker plate thing on this side too one day. I needed to do something else other than grind, brush and weld for a break so I did a tune up- wires were good so just plugs, Cap and rotor, fuel oil filter and cleaned k and n air filter, pcv valve. Trans, tcase and engine oil, coolant, brake fluid. . Manifold gasket. Fixed a bunch of small stuff. Problem I still haven't got to are- front right axle u joint, all three flex hoses and steel brake lines as they are pretty rusty. not to mention the wear items. Power steering leak somewhere behind the pump. Found out i have no interior dash lights. And my oil pressure gauge is fluctuating with the throttle application but reads super high.
