sporttruck88
Everything posted by sporttruck88
  1. Turns out it was the brake booster.
  2. 1JTML6310JT147367; 4.0,5-sp,Np231 and D30/D35 with 3.55s. Still on the road and I drive it to work. Dayton, Ohio.
  3. I had the same trouble with my '88, and the trouble went away after keeping the coolant topped off.
  4. Tractor Supply sells a winch mount that mates with a 2" receiver.
  5. I have an '88 MJ with a '90 4.0; when I start it up it idles fine but after I've driven it a while, the idle gets as high as 1600 rpm. If I shut it off and and restart it the idle goes back to normal but goes back up again after driving. Any thoughts?
  6. I had the same trouble with my '88, after I swapped my '90 4.0 in; when I changed the EGR valve and IAC valve it started running right.
  7. Does it take an Allen wrench or a Torx bit, to get the anchor pin bolts out of the calipers on a Dana 30?
  8. Maura- what a cool name!
