Everything posted by MJam86
Shakedown run at Slick Rock
Fabbed up some homemade rock sliders Here's the C-Rok
Installed a Cobra CB radio, husky truck tool box, C-Rok inner and outer brace, swapped in a 99 Dakota steering box, I utilized some hi lift hood mounts I had to mount my hi lift onto my tool box, added a Viair air compressor for OBA. Tool box sits right above compressor which is mounted in the bed.
Installed some Synergy hood louvers, beefed up my diff cover, flexed it out. Also my distributor bearing was toast so I replaced that as well.
I rocked it in 2wd for a bit, I ordered an advanced adapters SYE, Tom woods rear driveshaft, a D30 Lokka locker (great locker for $200 and I'm ditching the 30 eventually), and a few other miscellaneous parts like a 50" light bar. I locked the front, regeared to 4.88s, and locked the rear with a OX locker.
I had to drill knuckles and pitman arm for steering upgrades. Grind off the stock upper control arm mounts as they interfered with the new long arms. I also had to drill and tap a couple holes for the new cross member and skid system which is really beefy.
Now for the 4wd swap and lifting it! I decided sprung over using TnT u-bolt eliminators , TnT y-link long arms, RE 7.5" coils, RE 14" travel monotube shocks, IRO OTK steering with 5/8" heims, IRO trac bar (I'll be doing over the axle soon I didn't think this completely through), I grabbed a H.P. 30 for now eventually I'll be upgrading to bigger/better.
I decided to go with black and I believe lady in red color for liner. It may have been blood bath it's been about 2 or 3 months since I ordered so I forget.
Looking back this thing was hideous. I'm really pleased with the route I went.
While doing my research i started working on the body. I also grabbed a new set of 35s. Sanding it down, fixing dents, basically making it pretty. Eventually I decided to Monstaline it.
I did the major overhaul and repairs in a matter of about 1 week. I picked up a tranny/tcase , front/rear driveshaft, and some skids for a 1990 XJ for $200. I was only able to use front DS and then tranny/tcase. At this point I started researching what I wanted. I knew around 8" lift, 35 or 37s, long arms, lockers and all the other essentials I just didn't know what would be good for an MJ. I went from XJ, to WJ, to JK, and then to the MJ. I spent probably 4 months researching. I planned on doing trails like the Rubicon and Fordyce with this so I needed to plan things out.
You're correct it is RubberDuck's old truck
Replaced all fuel orings, basically I did a major tune up on this thing including cleaning the NSS. Then I started collecting parts for my 4wd swap.
It had leaks everywhere, valve cover, oil pan, coolant, fuel rail, pretty much everything. I replaced all gaskets, the thermostat, and soaked everything in degreaser followed by heavy duty pressure washing.
I began cleaning up the body, front windshield needed replaced, paint needed redone so I started thinking what route I wanted to go with that, I also started cleaning the undercarriage. The undercarriage was horrible! There was so much oil and grease caked on I didn't realize I had a D44 in the rear at first glance. I had a small case of blow by but replacing vac lines helped it mostly. I eventually added an inline filter to help
Brought it home and immediately set to work. The previous owner thought that the engine bearings were going bad so he put the MJ up for sale. turned out to be the water pump bolts were loose. I replaced the water pump, All the vacuum lines, cleaned throttle body, replaced 02, CTS, CPS, IAC, TPS, and refreshed grounds.
My 88 Comanche build thread. I bought this 88 Eliminator off a guy on here from Hayward, California. I believe it was purchased Nov. 15, 2013
Steering Box Frame Plating
MJam86 replied to Project Comanche's topic in MJ Tech: Modification and Repairs
Ever get it fixex? I had no issues myself but ended up installing my stabilizer because I feel it will help prevent extra wear on my parts. -
I'm just up the road an hour or so in Tracy, if you need help let me know you can borrow my box if need be or I may know a guy that has one for sell.
