matrix37495
Everything posted by matrix37495
  1. i have no idea, but if the deal fall through, I'm looking for new tires if the price is right
  2. i wonder if warranty will cover that? :D i still think he would have noticed the drag in the whole thing, and the sqeeling from the tires. how many mile would you have to drive to get that much damage
  3. looks great! keep up the good work
  4. i am also curious. i could use the extra fuel on the interstate
  5. yep! ^ on my car the are in the trunk going to the outside behind the bumper cover.
  6. i heard somewhere that you could put a cummins 4b in it. its a 3.9L turbo, just like the 5.9L in dodge rams but with only 4 cylinders.
  7. what about removing all the EGR stuff on a 2.5L?
  8. thats a good idea for the mounts, pete. i think ill use that idea. as for the dom tubing, what thickness and dia would you recomend? and where could i get a very inexpensive tubing bender? i want to do several projects that require bent tubes (id like to try a less complex vertion of patricks rig), but i can't find a bened for less than $3000. I'm looking for cheapest i can get that will bend dom tubing.
  9. i have a question about the OME 5" kit on ebay Link . is this any good? i was thinking about getting it as the price is right and its the amount of lift i want. Should i go ahead and get it or no? does anyone have experience with OME.
  10. awesome! thanks a bunch! not i i could just afford that dang $265 for the ax5 :D
  11. awesome! i have the 4spd but planned on swaping ing a 5spd. i guess ill be gettin killer fuel milage now! some told me the the 4 and 5 spds use different clutches. is this true? will i have to get new clutch with the 5spd or can i use my existing clutch(which is also newish)
  12. if you made roll bars, how much would you charge? I have a shortbed but the ebay bar is for show, I'm looking for something a little more functional
  13. I'm lookin for a roll ber for my MJ. do you know where that one came from? what vehicle?
  14. on JeepForum, someone said the the 4.10 gears are used with the 2.5L Here under gearing. so which is it? 3.54 or 4.10
  15. Hey! For you that don't know my truck from JeepForum.com; I have a 1988 Comanche base model. 2wd, 2.5L, ax4 My plans: 4wd converstion, 5spd, lift 5in( probably will be the first thing to get done), 33's, stacks!....more to come when i figure out what i want to do. This is my project truck once i rebuild my car motor. Pic:
