Everything posted by 500kalle
I mean The Four headlights!!!!!
Does somebody know, if The Chevy G20 lights fit The XJ-wagoneer Grill of My MJ?? Are they The Same size????
Does The headlight-switch of a '93 XJ fit my '88 MJ?? Both switches look a bit different!!!!
Nice rig!!!!! What Paste you Used for polishing The rims?? Are'nd they clear coated??? What brand and size?
Kalle's 1988 Comanche 2.5 4-Banger 2Wd The Build #3
500kalle replied to 500kalle's topic in Member Projects: Your Comanches
I Used tamiya Lexan Color for The Hard Plastc Parts, Dashboard and Steering column, for The doorpanels I Took some Special leather Paint!! It all Holds up very Good!!!! The wooden Parts I grinded with 2000 wet Sandpapier First and then sprayed with acrylic clear Coat!! The headliner console was sprayed with acrylic Color and clearcoat!! -
On The pics you may See that I changed The Instrument Cluster into a 1989s Xj's 4.0 one, incl the Senders!! Everything Works Fine but The tach!! There Must be some Kind of adjustable resistor at The back of The tach, so one may adjust it to The 2.5 Engine!! But I didn't find that adjustable resistor, does anyone here knows what it Looks like/where I may find it/how to adjust????? -
Everyone is permitted to borrow my ideas!!! ;-) THANKS for your compliments!!!!! -
Don't know Sem-products, Maybe that'll work better!!!
Ya, try it on a spot with tamiya Spray!!!
Caution: Don't use that dupli Color Spray!!!!!! If The Seat will become hot from Sun, you will glue on it!!!! Try a Good Color-Spray for Lexan Bodys for e.g. 1:10 Scale saloon racers!!! But try to Spray a Little Spot First, let it dry and then Test The quality!!!!!!
What Battery Shall I Buy??
500kalle replied to 500kalle's topic in MJ Tech: Modification and Repairs
Okay!! So I'll go to buy a cheap one!! There's an offer at the shop in my neighbourhood, a discounter brand 12V 65Ah / 540A? Will it work fine in My 2.5L4 MJ and even in My 4.0L6 XJ ?? It is a Johnson control one!! Called: Auto Fit !! -
Optima? Banner? Varta, .........????
Mine was completely rebuild(even the foam) and Covered with red and Black leather by an upholstery shop, I installed a New red carpet too and I covered The headliner with Black leather myself. And I modified an Old Xj Headliner console to fit in My MJ Centre console with Cup holder I modified from XJ Parts too!! ;-)
Where To Get A 60, Or 62Mm Throttlebody!?!?!
I searched and searched and searched for bigger tb and tbs, but there is nothing to find for My 88s 2.5 Single Point injected MJ!! But there is One Guy, friend of mine, who will build a bigger tb for My Comanche!!! His Name: BROCK HANSEN!!!! ;-) -
Great!!! I will have a Look in this evening!!! Thanksssssssss!!! ;-) -
Ya, I know, but a 60mm one should work perfect with a tbs and modified airbox!!! -
Today I painted the rear axle and installed a new diff.-cover: -
Kalle's 1988 Comanche 2.5 4-Banger 2Wd The Build #2
There's no chance to find a new, or good used headliner backer here in germany, so fixing with duct tape was the only way to rebuild it!! ;-) -
B Pillar Dome Lights Not Working.
500kalle replied to Zebvance's topic in MJ Tech: Modification and Repairs
If you find a not connected three-Port-Plug under The left side of your dashboard, you may try, by using a Voltmeter, to find Out The Connection from that plug to The wire you found! If there is a connection, you'll be right and The wire is for a Cargo light!!! ;-) -
THANKS!!! It was a lot of work, but I love it!!! ;) -
Hi!!! Steering is built by a company named FK !!! Don't know any more of it!! :-(
