Whamm
Everything posted by Whamm
  1. Pm Sent Great looking stickers. It will be the only thing that I don't have to fix on the truck. :D
  2. Other than the timing kit anything else I should change out? (i.e. Waterpump?)
  3. My bad, through the thottle body.
  4. I have a 90 Comanche with 4cyl with about 275XXX miles. I was driving and all the sudden it lost power and began backfiring. It made it home barely. I am guessing that it has jumped time. It will not start now but does turn over. Will be checking the time the old fasioned way. Just wondering before i repalce the chain and other parts if there could be any other issue that i should check for.
  5. Thanks for all the help and pics. The main problem that i was having (90 Comanche 2.5 4x2) was the trans would not shift into any gear once in was removed from reverse. And all gears would grind when shifting. So i figured that it had to be the clutch and/or slave cylinder. There wasn't any noise from the trans when in gear, but the shaft moved about an 1/8 inch on the inside race.
  6. Thanks, not something that i wanted to do but when i took the trans out to replace the clutch i noticed that the shaft had a lot of play in it. Well i guess if it blows up after trying to rebuild it, i haven't lost that much and gained a little knowledge. :nuts:
  7. I need to replace the input shaft bearing in my AX 5. Does anyone know of a transmission tech sheet that i can use to open up this trans.
