Luvtohunt
Everything posted by Luvtohunt
  1. Would like to chang the valve cover gasket on my 88 MJ with an inline 6 Cylinder. How difficult is this to do? Any advice or tips? Thank you.
  2. Rolled the passenger side window down tonight, but cannot get it to role up. The handle just spins. Any advice on whats wrong and how to fix it? Thanks again.
  3. Was there a factory brush guard made for the MJ? If not will a XJ brush guard fit? Thank you for your input.
  4. Any pictures you could share? Thanks
  5. Any idea on where to order one from? Thank you.
  6. Thanks again for all of your help. Its greatly appreciated. :cheers:
  7. Going to rattle can paint my MJ, just looking for advice on what grit sandpaper should I use on the original paint to aid the paint adhering? Thanks again for your advice.
  8. Going to install front coil spacers this weekend. Any advice on how to safely do this? Thanks again for all of your help, its greatly appreciated.
  9. Getting ready to install new extended rear shackles. Looking for advice on how to do this. Do you jack the body up? Any information would be appreciated. Thanks again for your help.
  10. What is the round unit on the left hand side attached to the front bumper? Thanks,
  11. Can one be installed, and if so, are they beneficial? thanks again.
  12. Did all MJ's come with a rear sway bar? If so, mine does not have one. Can a new one be installed if it originally didn't come with one? Any information on this would be appreciated. Thanks for your help.
  13. Any idea where to get the metal retainers? Mine are completed rusted to nothing. Thanks. I believe that someone still has them available, but the easier way to fix it would be to use stainless bolts. don't bother with the strip, washers work just fine. Really, don't need the strips. That would make things alot easier. Just stainless bolts and washers? Also, do you replace the black plastic liner? Thanks again for your help, its greatly appreciated.
  14. Any idea where to get the metal retainers? Mine are completed rusted to nothing. Thanks.
  15. Could you post of picture of the tempature sender, or describe it? Thank you for the information.
  16. How do you properly bleed the system? I looked all over and did not find any directions or mention. Appreciate the info.
  17. Will the fender flares off of an 88 Cherokee fit an 88 Comanche front and back? Thank you for the information.
