tommy90
843 profile views
tommy90's Achievements
  1. Perfectly nice bed.it is cool but I almost wanna buy it just to keep for a future project. http://nmi.craigslist.org/for/4101594958.html
  2. So this is a riunning and driving Comanche? Where at in Michigan?
  3. I pulled a astro van on a Dolly with my 2.5 4 cylinder Comanche.engine blew a valve I'm pretty sure.had horrifying blowby. 4 month old slave cylinder blew 3 days after blow by started occurring.
  4. It appears a parts truck of mine has this little rectangle with three screens in it 2 small ones (one in the clock) and one big screen in the middle.never have I seen one.is it sought after or valued?this unit is to the right of my steering wheel directly above the cigarette lighter.
  5. Hmmm maybe use some fat washers and some homemade shims. That's the early 2000 bumper right? The one with the other caps are the generation before the one I believe I'm talking about.
  6. Just need to know what kinda modifications you have to do. Thanks in advance.
  7. So I've heard that a early 2000's s-10 bumper will bolt up to an mj? Is this true
  8. So from what I read you can take Cherokee 2 door bucket seats and they will bolt into an mj? I know 97 and up mirrors bolt on.what else is bolt on from the Cherokees?
  9. Its called an inverted torx bolt.found that out when my 2.5s starter took a crap and had to buy the inverted torx socket.
  10. If it is an internal throwout bearing check the holes where the bleeder is sticking out of to see if the rubber grommets in the Hole for the bleeders to stick out of is gone.if not line with hit the case being there's no rubber grommet there.happened on my 2.5 4 speed after I did the clutch,did the same thing.just give it a look its probably what it is.good luck. P.s my clutches throwout bearing went 4 month later after letting it tick.guessing my line from the throwout bearing got a hole from rubbing
  11. Yup small wheel base.I'm only 20 in college and instead of wasting money on my trashed bed.
  12. Looking for a bed for my 90 sport truck.little to no rust wanted. Also a rear bumper. Thanks I'm in the Detroit area.
  13. Looking for a 4.0 5 speed Comanche. Have a 90 sport truck black 2.5 with 7,000 miles.auto trans that shifts good.needs floor patched. For trade plus a little cash for any 4.0 5 speed Comanche. Text or call 586 209 6334 for ics and details.4wd not necessary.
