8.25 a good axle swap???
You'll need to move the leaf perches. Yes, the early 8.25 is better, just not by a whole lot. The later (97+ I think) 8.25 is an excellent upgrade. An XJ/MJ dana 44 is even better, though can be harder to find and older (probably needs seals and stuff). A ford 8.8 from an Explorer is a significant upgrade and 96+ have disks.
The only down side to the 8.25 axle beside only being marginally stronger then the d35 is the gearing only goes to 4.56 and you are limited on your choice of lockers :brows:
To me the 8.8 is a far supperior swap then even a d44. The only advantage the d44 has over a 96 or newer 8.8 is gear selection. If you never plan on going deeper then 4.88 you are golden with a 8.8. Also with the 8.8 you get 31 spline axles, and disc brakes :D
