Heat/ AC problem
I have managed to get my AC to blow through the vents but now I can only get the heat to come out of the defrost vents. I had a question about what all of the vac. actuators and relays were doing behind the glove box. It doesnt look factory but then abain it does. I would like to be able to contact someone who has a 2.5 5 speed with air to compair the two. The vacume lines behind the controls are as such
Will the heat only come out the defrost too? Check the football looking thing behind the bumper on the passenger side for cracks. Check the line that run to it.
Yes...that is a very good possibility. It is a vacuum resevior and if it leaks or a line going to/from it leaks you will have these problems.
I noticed that the vacume switch behind and below the glovebos may have been the culpret. I just need to see another view of another manches heat and ac panel to compare the two. I am just really curious what all the relays and actuators are for back there? I had heat working fine the way it was hooked up but after switching things around and reconnecting the vacume lines right thats where the problem is
