CrankShaftKid Posted May 13, 2008 Share Posted May 13, 2008 Guys, My MJ won't start. Fuel is there. It cranks, but I put the timing light on the #1 wire and nothing is showing. Recently pulled the dash and reinstalled. It fired up after I finished, now nothing. Also, the aftermarket tach the PO installed now doesnt work. And it seemed like it went out before it stopped cranking. What should I check? Thanks Link to comment Share on other sites More sharing options...
offroader461 Posted May 13, 2008 Share Posted May 13, 2008 check the CPS(crank position sensor) and also check your computer ground...may have knocked it loose when you put the dash back together Link to comment Share on other sites More sharing options...
CrankShaftKid Posted May 13, 2008 Author Share Posted May 13, 2008 Thanks. And 88 5speed Link to comment Share on other sites More sharing options...
CrankShaftKid Posted May 13, 2008 Author Share Posted May 13, 2008 CPS was the culprit. Had a burned wire and the whole thing just looked like crap. Plugged the new one in, bolted it in, and it fired right up. Chalk up another one for the CPS! Link to comment Share on other sites More sharing options...
