i know this has been beat to death but
i can't find the right info in NAXJA and CC searches so.
bottom line: part time indicator lamp came on and won't go off
info: jeeps always been hard to pull into 4wheel like the linkage was stuck so i WD40 it... nuetral jeep off easy to pull up now move into 4hi>2hi>4hi>2hi turn on jeep part time lamp is on... ¿que? so i back out thinking its just acting up and it stays on. i do a burn out. one skid.
take it to gravel lot try shifting through all t-case positions lamp still on.
burn out in 4lo 2 skids 4hi 2 skids try jeep on incline with front on pavement rear on gravel burns out slow to move DEFINATELY not in 4wheel
I'm thinking vacuum disconnect?
Probably... Put it in 4hi or lo and see if you can spin the front driveshaft freely. If you can't, your tcase is fine and it's the disco. In that case it sounds like the vacuum switch in the back of the tcase.
I'd just perma-lock it.
I AGREE!!
Its the DISCO not the T-case!! I believe www.GOJEEP.com has a write up on maitaince of this unit. Not hard, check the vacuum lines as well.
Check the pass side inner fender. Is there a little bracket with a blue thingie attached? It should have a wire or two and a air line into the bottom. This is your switch to turn the light on the dash for 4WD. If no, yours may be the wired version all on the disconect at the axle.
In any event, its most likely that your front axle is NOT disconnecting when the T-case is shifted out of 4WD. Annoying but not a huge deal if the front is still open.
CW
CW
thanks i deff have the wiring in the fender i see it all the time and wonder "hmm if only i knew what that was" then promptly forget its there. lol.
no damage will be cause to anything if i leave it locked correct?
(completely stock front axle)
Nope. No issues. It'll just make your front D/S spin all the time. Hopefull it's not bent or anything, because you'll know with it spinning...
I converted mine to a one-peice shaft. But that was because my new carrier (trutrac) wouldn't work with the two peice ones.
sweet as long as 4wd works
it was in 4wd on the pavement for like a minute and i tried to dump the clutch and spin em and nothign... just alot of acceleration... I'm thinking 242 at the same time as the new tranny would be cool.
thanks for all the help yall.
-nick
