bigwormskidoo Posted May 13, 2006 Share Posted May 13, 2006 I'm doing a 2wd to 4wd conversion on my mj and i need to know what length front drive shaft to use with it it has a 4.0 ,automatic trans and a 231 t case dana 30 front i did another conversion a while back and used a driveshaft out of a 4.0 5 speed 231 equiped mj it was a little short so i figure there are different size driveshafts for different equipment :cheers: Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 13, 2006 Share Posted May 13, 2006 Can't tell ya the length, but an XJ (Cherokee) with the same drivetran will have the front shaft you need. Easy to get. Link to comment Share on other sites More sharing options...
