djag12 Posted May 8, 2008 Share Posted May 8, 2008 Are the xj and mj rear axles interchangeable? Link to comment Share on other sites More sharing options...
89eliminator Posted May 8, 2008 Share Posted May 8, 2008 you'll have to weld on your own spring perches. Link to comment Share on other sites More sharing options...
Motion Offroad Posted May 8, 2008 Share Posted May 8, 2008 The XJ is spring over (SOA) and the MJ is spring under (SUA). Also the location of the perches are different between the two. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 9, 2008 Share Posted May 9, 2008 Shock mounts are also different XJ to MJ . They are even different between MJ long and short beds. (Although the actual mount is just installed reversed.) Can you make them work? With a welder and cut-off wheel, absolutely. CW Link to comment Share on other sites More sharing options...
