does anyone have a broken computer for a renix engine? i need some parts from it. let me know, and if you do, we'll work out something for the exchange. :bowdown:
I don't have any "Broken" ECM's but I have a few of the different ones, which one do you need??? Year and Auto or Manual?? Or the last 4 digits.
1 have a 1988 no markings comanche. it has a ax15 that was put in it. i have no idea what was in it before. maybe i should get the # off the computer? no junk yard around here has one, so i'm stuck.
I've got three renix ones sitting around...
87 4.0/4x4/5 speed
88 4.0/4x4/5 speed
86 2.5/4x4/4 speed
I know the two 4.0 ones are good, no idea about the 2.5, never ran the truck.
If your have a '88, 4.0, manual transmission, the ECM would be a #5300 5407. The Number will be in very bold print on the unit.
You didn't say what engine you have :dunno: And I don't have any 2.5 ECM.
The only difference on the ECM's is the 2.5 or 4.0, Manual or Automatic, and of course - '87-88 and '89-90.
Then you would need the #5300 5407 ECM.
The ECM is mounted behind the dash, just above the gas pedal, to the right, like behind the heater controls, you can pull it out, by removing a screw and slide it down, to un-hook the connector, with out removing the dash.
It will be the big silver colored box, about 6' x 8' x 1".
Drop me a PM with your shipping info, and a fair offer......and I'll ship one out to you ;)
ok ok, computer # in bold print # ef8953005226
in small number in corner of the box 8736
made in france
the computer was bolted on with three 8mm bolts
i took off two of them to get the number, the top bolt is a pita to get too, but if necessary i can remove it to drop the computer down.
engine # 903 mx 27
what year is engine?
its in a 1988 comanche, but i have found some strange things on this vehicle so--------
:brows: :chillin:
:hmm: I searched '81-'93, 5k pages and could not come up with that number :dunno:
What your saying is, you have a 5300 5226 microprocessor and what my parts list calls for is a 5300 5407 for a '88 w/manual transmission.
The only thing I can think of, is to go thru the pile of ECM in the shop, and see if that number shows up......I got all the #'s to take with me.
Yea.......I think so :???:
made in france
Yea.......they all are = Renix ;)
If the 3 screws were still in the bracket, then it could be factory installed??
I guest the next question is........what's wrong with your ECM now???
Footnote: I cross checked a couple supply houses, came up with this-
Cardon # 792858 Picture here
Niefoff # 5300 5429
Standard # 5300 5429
nothing is wrong with my computer. i just need the hook up on the computer that hooks to the engine harness. i am going to build a megasquirt for my mj.
the parts america picture isn't mine.
i will take off the last bolt, and take a picture; tomorrow
do you think a xj computer would be the same? renix and all that?
if i could find a bad one. i hate to tear up a good one. :popcorn:
Image Not FoundImage Not Found
i need the black conections you see in pictures jamminz.gif [/img]
does yours look like this?
I did find one :D Looked thru about 10, and the last one.......Here a picture of it, but I didn't take a picture of the connector :cry:
so......either my parts list is wrong......or I'm going :nuts:
And when I removed this, I wrote '88, 4.0, BA10 on the ECM.
So, what ever you want to do, drop me a PM and we'll take it from there.
