So the local club had a trail clean up this weekend and I guess my throw out bearing decided it wanted to go out. So I am going to replace the clutch and every thing. So who do you guys like to go with for a replacement??? And how hard is it to replace and should I have the fly wheel ground down/clean up.
Luks (Luchs?) made the factory clutches.
DO NOT have the flywheel resurfaced. The FSM specifically warns not to do so. If you do, you will ALWAYS have clutch problems.
