probably a dumb question
but since the xj and mj share engine stuff, can the air intakes advertised on like summit, or jegs for the xj, work on a mj?
The engine compartments are identical, and the aftermarket XJ/MJ intakes will interchange.
not entirely true...make sure what engine you have first...the H.O. intake setups won't work on the renix era engine due to the mounting on the T/B being different
Of course. I ASSuMEed he knew the engines had to be the same. But you are absolutely correct. :roll:
