fatcat0491 Posted April 26, 2008 Posted April 26, 2008 How can i turn a column Shifted Comanche into a floor shifted Comanche. I Hate Column Shifters :hateputers:
CWLONGSHOT Posted April 26, 2008 Posted April 26, 2008 Get the related parts from a donor XJ and install...... :roll: ;) CW
fatcat0491 Posted April 26, 2008 Author Posted April 26, 2008 How descriptive ;) But i get your drift
CWLONGSHOT Posted April 26, 2008 Posted April 26, 2008 How descriptive ;) But i get your drift It is as simple as that.... As you remove the parts from the XJ, you'll see how to put them into the MJ. Then just remove the stalk form the column and your done!! CW
HOrnbrod Posted April 26, 2008 Posted April 26, 2008 How can i turn a column Shifted Comanche into a floor shifted Comanche. I Hate Column Shifters :hateputers: Just curious: why do you Hate column shifters?
fatcat0491 Posted April 26, 2008 Author Posted April 26, 2008 I Like having to shift Lower then right bye the Steering wheel Its also more comfortable driving experience :nuts:
HOrnbrod Posted April 26, 2008 Posted April 26, 2008 I Like having to shift Lower then right bye the Steering wheel Its also more comfortable driving experience :nuts: Errrrrrrr, okay.
carnuck Posted April 26, 2008 Posted April 26, 2008 I'd like to buy your shifter cable! (sadly, I recently gave away the floor shifter I had) There is a plate on your floor that covers the hole where the shifter goes. My cable accidentally got broken while pulling the column from a junkyard MJ.
fatcat0491 Posted April 26, 2008 Author Posted April 26, 2008 if i do this i will gladly give you the cable
