fatcat0491 Posted April 26, 2008 Share Posted April 26, 2008 How can i turn a column Shifted Comanche into a floor shifted Comanche. I Hate Column Shifters :hateputers: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 26, 2008 Share Posted April 26, 2008 Get the related parts from a donor XJ and install...... :roll: ;) CW Link to comment Share on other sites More sharing options...
fatcat0491 Posted April 26, 2008 Author Share Posted April 26, 2008 How descriptive ;) But i get your drift Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 26, 2008 Share Posted April 26, 2008 How descriptive ;) But i get your drift It is as simple as that.... As you remove the parts from the XJ, you'll see how to put them into the MJ. Then just remove the stalk form the column and your done!! CW Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 26, 2008 Share Posted April 26, 2008 How can i turn a column Shifted Comanche into a floor shifted Comanche. I Hate Column Shifters :hateputers: Just curious: why do you Hate column shifters? Link to comment Share on other sites More sharing options...
fatcat0491 Posted April 26, 2008 Author Share Posted April 26, 2008 I Like having to shift Lower then right bye the Steering wheel Its also more comfortable driving experience :nuts: Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 26, 2008 Share Posted April 26, 2008 I Like having to shift Lower then right bye the Steering wheel Its also more comfortable driving experience :nuts: Errrrrrrr, okay. Link to comment Share on other sites More sharing options...
carnuck Posted April 26, 2008 Share Posted April 26, 2008 I'd like to buy your shifter cable! (sadly, I recently gave away the floor shifter I had) There is a plate on your floor that covers the hole where the shifter goes. My cable accidentally got broken while pulling the column from a junkyard MJ. Link to comment Share on other sites More sharing options...
fatcat0491 Posted April 26, 2008 Author Share Posted April 26, 2008 if i do this i will gladly give you the cable Link to comment Share on other sites More sharing options...
