Bacon Posted April 16, 2008 Share Posted April 16, 2008 i'm looking at buying a set of used longarms. the only issue is they are on a truck whose mount is welded to the frame, so the mount does not come with it. what do you guys suggest for a longarm frame mounting system. I'm not in a position to fab one, as my fabbing skills just aren't there. I'm looking at buying one. clayton's looks good, what do you guys think? any other places I should look at? Link to comment Share on other sites More sharing options...
Motion Offroad Posted April 16, 2008 Share Posted April 16, 2008 What longarms are you buying? Different setups (TNT, Claytons, RK, RE, Full Traction, Etc.) all use a different location to mount the arms on the body side. Not to mention that they all use a different type of joint; thus being a different size mount. Also different arms are different lengths, so your control arms may be to short or to long with another mount setup. For instance a TNT arm won't work on a RE mount. I'd figure out what type of arms your buying and try to get the correct mounts for them. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 16, 2008 Share Posted April 16, 2008 :agree: Link to comment Share on other sites More sharing options...
