RedBullMJ Posted April 15, 2008 Share Posted April 15, 2008 I am swapping a 2000 TJ drivetrain into my Comanche. Does anyone know if a 2000/2001 XJ dash, steering column and wire harness is the same as a 2000 TJ. The goal is to swap the entire XJ dash / column and TJ wiring harness, so I can just plug and play. The other alternative is to bolt in a TJ steering column and hand wire the rest of everything else. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 15, 2008 Share Posted April 15, 2008 not even close to the same. even the wiring is different. the looms will be different lengths...probably some of the same connectors if not all, but different lengths none-the-less. the dash from a tj won't bolt in either. you need all xj parts for a direct swap. but, that doesn't mean you can't put it in there :brows: Link to comment Share on other sites More sharing options...
RedBullMJ Posted April 15, 2008 Author Share Posted April 15, 2008 ok, thanks..... The motor tranny and t-case are in...the 3550 is a bit longer, so minor adjustments are need for the crossmember and shifter.... Link to comment Share on other sites More sharing options...
