loose track bar
I think the tapping Ive been hearing may be my trackbar. I assume I will need to drop the front skid to get to the track bar nut. But it doesnt look like there is anywhere near enough room to get a torque wrench in there. Should I just tighten it down as much as I can or is it bad to over tighten it? What size nut is it?
Good chance of that, i heard a similar tapping and tightened down the track bar, 100% gone.
I left my skid plate on when i got at it (it was the upper bolt) but my front end is currently out of wack, so not sure if you can do the same.
I think i put the socket on the nut, then attached the wrench to the socket once it was already on.
