ejndssn Posted May 5, 2006 Posted May 5, 2006 As you folks already know i was and still looking for ax-15 external slave bellhousing setup from the local bone yards and a very hard fine so far and no luck some on the net but the price is very high. just wondering :idea: if i would tap and bolt the internal slave in place and apply some loctite would this work. until i replace this with an external setup. any suggestion would be greatly unless one of you folks happen to have one your back pocket :D
Cabz Posted May 5, 2006 Posted May 5, 2006 As you folks already know i was and still looking for ax-15 external slave bellhousing setup from the local bone yards and a very hard fine so far and no luck some on the net but the price is very high. just wondering :idea: if i would tap and bolt the internal slave in place and apply some loctite would this work. until i replace this with an external setup. any suggestion would be greatly unless one of you folks happen to have one your back pocket :D Nope :cry: The internal slave bell houseing does not use a release arm , the slave pushes directly on the P Plate. The external BH has a release arm that the slave pushes on . In short your gonna have to pull the trans either way.
ejndssn Posted May 5, 2006 Author Posted May 5, 2006 sorry folks let me mention that i have replaced the internal 2x already and lost the flared roll pin in its place i would be the bolt vice the roll pin
