92comanche4x4 Posted March 28, 2008 Posted March 28, 2008 is the t case supose to like easy to shake up and down?
Pete M Posted March 28, 2008 Posted March 28, 2008 Is is securely attached to the trans? Meaning that the trans moves up and down too? You might need a new trans mount. Easy/cheap to do on a 92.
92comanche4x4 Posted March 28, 2008 Author Posted March 28, 2008 ya its attached to the trans i was lookin at that the day i did the 3in coils.would it hurt the t case after i get the 4x4 workin?
Pete M Posted March 29, 2008 Posted March 29, 2008 The trans should be solidly attached to the transmission crossmember. If you can stick a crowbar under the trans and lift it up, then you should put a new trans mount on your list of parts to get.
