egr vacuum lines
Can some one explain or post a pic of where the vacuum line from the transducer connect to the egr valve? My haynes is a little confusing and One of my lines I found just had a screw in the end so I want to make sure they are connected right. Can you replace the transducer w/out buying the egr?
