I have a 1988 4.0L that has 8,000 miles on it and i want to put it into my 1987 Comanche pickup. Not a big deal, but the problem is that the new engine had an automatic transmission on it and I have a manual transmission. Is there going to be a problem, or is it even possible to use this engine in my truck?
And change the TPS to a Manual transmission and remove the TV cable bracket at the throttle body.
Change out the flex plate with the fly wheel.
And a couple other little things, But Very Do-able.
