48wilys Posted February 22, 2008 Posted February 22, 2008 I have an 88 MJ with the 2.5. In the morning when I start it up it will run for about 5 mins, and then stall. After that I am lucky if it will run for a minute after I restart. If I keep my foot on the gas just a little, it will stay running. Also until it warms up it hesitates, and will buck at just about any speed. I have notice that the dash lights flicker just before it dies, but I am not sure that it is realted. It seems to be worse when it is wet. I have tuned it up, replaced the fuel filter, EGR valve, coil, and a broken wire in the harness. I have good fuel pressure from the pump all the way to the TBI. I am lost and could use some help :headpop: Thanks
mjeff87 Posted February 22, 2008 Posted February 22, 2008 disconnect the O2 sensor and see if the problems go away. If yes, replace the sensor. Jeff
48wilys Posted February 22, 2008 Author Posted February 22, 2008 Thanks for the O2 info. I disconnected it this am, and ir seems to have solved the problem. I am going to replace it tomorrow. Again thanks for the help
mjeff87 Posted February 22, 2008 Posted February 22, 2008 :cheers: Glad to hear.... I had the same problem on my 87, and chased it for months trying to figure it out. Jeff
