i noticed a hose that was missing from my comanche and wanted to know if i needed it...
i have a pic of a comanche engine bay and circled the hose that is missing..
Image Not Found
The hose brings in clean, filtered air (as part of the CCV system) which is then mixed with crankcase vapors (i.e. blowby, fumes) which gets sucked back into the intake manifold (via the small tube at the back of the valve cover). I highly recommend replacing the hose! :)
