MWinland Posted February 15, 2008 Share Posted February 15, 2008 I've seen so many different seal numbers, and I don't know what's correct. To eliminate the vac disco and upgrade to a 1 piece shaft, what seals do I need? Link to comment Share on other sites More sharing options...
Wildman Posted February 16, 2008 Share Posted February 16, 2008 I think this link will give you what your looking for, check it out ;) http://www.madxj.com/MADXJ/technical/te ... dSeals.htm Link to comment Share on other sites More sharing options...
jeepthing07 Posted February 17, 2008 Share Posted February 17, 2008 The Mad XJ write up is just for the 297X disconnect shaft swap, not for the disco delete swap. I just stuck a 1 piece axle shaft in my YJ and you need to pull the diff out and put a seal (national part #471763) where a non disconnect seal would normally be (its not machined to use a regular seal). the seal in the disco housing won't be needed anymore but i just left it there as a dam to maybe keep mud from filling up the disco housing. Link to comment Share on other sites More sharing options...
