wondering if the 304 v8 matches up to an ax5 5 speed tranny in my 86 comanche if not which trannies will fit it. and also will a 258 match up with the ax5 tranny :hateputers:
I am not sure about bolting up... but in do know that the ax5 isn't going to stand up to much more then a little bit v6. Probably have to swap to the AX15 before anything...
I'm sure someone will chime in with a good swap combo.
wondering if the 304 v8 matches up to an ax5 5 speed tranny in my 86 comanche if not which trannies will fit it. and also which engines will fit the ax5 tranny other than the 3.4l v6 :hateputers:
The 304 (and the 360 and the 390/401) and the 258 all mate up with the AX-15, not the AX-5.
A 304 would shred an AX-5 in about 45 minutes ... less, if you put your foot in it.
