carone Posted February 5, 2008 Share Posted February 5, 2008 I am starting my RK long arm install but I have a few questions. Do you have to notch the cab mounts for the long arm LCA mounts? How did you get around the fuel lines with the drivers side long arm LCA mount? Link to comment Share on other sites More sharing options...
DrThunder Posted February 5, 2008 Share Posted February 5, 2008 i got rid of my lower control arm mounts completely. i'm sure this is the case for you too. Link to comment Share on other sites More sharing options...
Blue XJ Posted February 6, 2008 Share Posted February 6, 2008 I am starting my RK long arm install but I have a few questions. Do you have to notch the cab mounts for the long arm LCA mounts? Shouldn't have to, mine fit on just fine on the stock rail, there aren't really any cab mounts since its a unibody up front. How did you get around the fuel lines with the drivers side long arm LCA mount? Pull them away from the frame, put the bolts in, then put the lines back inside the mount, then install the upper arm. Thats how I have done both kits, never had a problem. I ran the bolts from the inside out though, so the bolt heads were on the inside of the frame Link to comment Share on other sites More sharing options...
