here's a weird one I went outside to warm the truck up and when I came back out to leave for work I had no power to the heater/ac controls so I figured the blower went out. So I went to turn on the windshield wipers and no wipers at all but the lights and everything else worked.
Then I go out the next day to check the fuses and now the heater and windshield wipers work fine??? No problems since.
I'm lost on this one.
88 jeep comance 2wd 4.0 manual
88 jeep comanche 2wd 4.0 manual
Most likely the ignition switch is the problem. Either it is failing or it stuck and didn't return fully after starting it.
My wipers drop out and I just push on the fuse panel with my foot and they work again. I should replace the entire fuse panel and electrical. PO did a fine job wiring it with extension cords. :dunce:
Yeah thats got to be it makes sense now. Thats really the only point to where the wipers and the blower relate. And the last few days the ignition has been sticking as I turn the key. I put some wd 40 in there hopefully that does the trick.
Thanks for the help.
