Car RamRod Posted January 23, 2008 Posted January 23, 2008 I've seen a few ways that people have rigged parking brake cables onto a disc brake 8.8, here's my setup: You'll need: stock brake cables brake cable ends for the 8.8 (came on mine) a few inches of pipe (I think it's 5/8", I don't really remember) 2 washers with either a 1/2 or 9/16" hole weld the washer to one end of the pipe, and use that to clip the stock cable into. don't forget to notch the end of the pipe so you can release the collars. weld the ford loop end onto the end of your oem cable. run your cable through the pipe and little bracket thingy on the ford rear then weld the pipe onto the bracket where the ford cable once clipped in lastly, I had to lengthen my adjuster, which may not be the case for everyone but I had to make it about 1/2" longer pictures are worth 1000 words: washer/pipe setup Image Not Found 2 views of the connection to the brakes Image Not Found Image Not Found additional length: Image Not Found hope this can help someone out, Matt
CEThomas Posted January 23, 2008 Posted January 23, 2008 Or you can use the MJ stock cable and get 2 small cable clamps and just loop the stock cable and clamp it ;) Works great, takes about 5 min. and cost under $2 :cheers:
Car RamRod Posted January 23, 2008 Author Posted January 23, 2008 I'd seen that, but I wasn't too stuck on the idea. Don't get me wrong, I rig up as much stuff as the next guy, but I like to go the extra yard on the parking brakes since I park on hills alot.
HOrnbrod Posted January 23, 2008 Posted January 23, 2008 I just slotted a couple of OEM Ford clevis brackets and inserted the original ebrake cable. Works great.
