aussiebob Posted yesterday at 03:20 AM Posted yesterday at 03:20 AM Installed Dorman Exhaust Header ends up a little thinner than the stock Jeep Inlet Manifold ears any thoughts 88 4.0
pizzaman09 Posted 5 hours ago Posted 5 hours ago If your good at welding, you could build up a bit of material right under where the bolts hit in the exhaust header and grind and file it to height to match the intake. Or you could machine or file down the intake to match the exhaust.
