1987 Comanche Laredo Diesel - $6,000 - North AL
ThreeComanches
Hi all, I hate to be making this post but life circumstances have become more demanding and I'm having to cut some of my toys loose.
Up for sale is a 1987 Comanche Laredo Turbo Diesel. It is a factory diesel, I have the documentation to prove it. Clean title in hand. As far as I can gather, only 4 1987 Comanches with a factory diesel exist. This is the only known Laredo. This truck will start and run but doesn't drive. It is missing the driveshaft and has 0 brakes. My plan was to do an original spec restoration. Can provide videos of it running and more info via PM.
Asking $6,000 but will consider reasonable offers. No trades.
History:
Truck was sold new in Salem, OR and was in OR until 2025 when I towed it to AL. Original owning family had it until 2024. It has been off the road since 2016. In that time, it was swapped to a 2.5 gas sometime in the late 90's/early 2000's. The next guy that had it (a kid) took the bed off and chopped the fenders. I bought it in July 2025 and towed it to Alabama myself. On the trip, the hood flew open because the last guy removed the hood latches and never told me.
What’s been done:
2.1 Diesel engine installed (65k miles, documented)
AX5 manual installed (83k miles, documented)
2WD front axle and stock front suspension reinstalled  (it had a sketchy lift when I first got it)
Bed installed
Firewall repaired from hood incident (cowl still needs attention)
Whats left:
Button up steering arm
Install new clutch cylinders
Install new brake hardware
Needs a driveshaft (original one was cut for the gas engine)
Bolt down bed
Fuel hoses need to be finished (one leaks and one is missing, hard lines are good.)
Oil pan gasket (it leaks)
IMG_4629.JPG.d8d79656ffea12e353f57dbaec3df71a.JPGIMG_5310.JPG.11d369660b9aa5f873d4aa6dfe23a60d.JPGIMG_5309.JPG.af3bbb7532dffe0727440b7bfce1abf0.JPGIMG_5313.JPG.598549c9e4c73b8b7c03e6259f1d934f.JPGIMG_5314.JPG.a650777b0e00d3a0759e532feb9afa44.JPGIMG_5315.JPG.a462f5e2fb0cc536d088a0c369873133.JPG
Archived
