Sasquatch Posted January 1 Share Posted January 1 I'll attempt to add as much info as I can with my limited knowledge. Heck, 72 hours ago I had no idea I'd drive a Jeep Comanche home to play with. Once I remove the protective coat of rust from everything, I'll update and make corrections.... I do know the engine has been swapped to a Jasper Inline 6 but that's about it. I'll continue updating the page (Trans/Axles, Etc...) as I learn more. Here's what I know to be true. 1989 Jeep Comanche Swapped Jasper Inline 6 Build 03/1989 Sitting on private property in Upstate SC Tagged, Insured and drove it home from Bristol area TN. Although drivable, it's going to be a fun project for me to repair, modify, and upgrade. That's the proper way for every Jeep owner, right? Bench seat, cloth insert with vinyl trim (is that custom?) 4 sp Auto trans on the column 7' Bed Burgundy Interior - (That will definitely change) Silver/Burgundy with Pinstripe detail exterior. Floor panels are solid, some rust on the axles and hub areas. A few holes in the rear of the exhaust pipe. Spare tire (baby) Weird Side mirrors with a few extra holes in the door. Makes me wonder what was original and how many time they got knocked off/destroyed.... I've started a project thread where I'll document the build/clean/restore project here. My '89 Comanche Project Link to comment Share on other sites More sharing options...
jdog Posted January 22 Share Posted January 22 BODY: TL62 BUILD: 03/01/89 SELLING DEALER: BOB BEARD JEEP EAGLE AUGUSTA, GA *D1 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE BAYP 105 AMP ALTERNATOR BCYP 95 AMP BATTERY CBAP STRAIGHT BACK BENCH SEAT DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DHTP SHIFT-ON-THE-FLY,P/TIME T/CASE EAAC ALL ENGINES EAFC ERB 4.0L I6 MPI ENGINE GRVP LEFT MANUAL MIRROR HAA AIR CONDITIONING JHA VAR INTERMITTENT WINDSHIELD WIPERS MDA FRONT LICENSE PLATE BRACKET PS3 Dover Gray RAAC ALL RADIO EQUIPPED VEHICLES RCAP SBAA POWER STEERING SUA TILT STEERING COLUMN TAAC ALL TIRES TNCA P195/65R15 BSW AS TOURING TIRES YGBA 1 ADDITIONAL GALLONS OF GAS YGGA 9 ADDITIONAL GALLONS OF GAS Z01P REAR SPRING GROUP I Z59P LEFT FRONT SPRING GROUP IX Z79P RIGHT FRONT SPRING GROUP IX 5ALA APAS MONOTONE PAINT BGAS POWER FRONT DISC/REAR DRUM BRAKES BJAS DESCRIPTION NOT AVAILABLE BKPS 10X2.5 REAR DRUM BRAKES CKJS BLACK VINYL FLOOR COVERING CSRS DO NOT USE - SEE CLASS JV DGSS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHAS LOCK-UP TORQUE CONVERTER DMDS 3.55 REAR AXLE RATIO DRJS DANA 35 REAR AXLE GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS GEHS FIXED DOOR VENT GLASS GNAS REAR VIEW DAY/NIGHT MIRROR GUAS OPEN JAAS INSTRUMENT PANEL JAZS DO NOT USE - SEE JP, KA CLASSES JBFS INSTRUMENT PANEL BLACK BEZEL JCAS SPEED GRADUATION-MILES JKBS KWXS BLACK BADGE K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS SEAT BELT ALERT-DRIVER SEAT ONLY LBCS GLOVE BOX LAMP LCJS OVERHEAD AMBIENT SURROUND LIGHTING LMAS HALOGEN HEADLAMPS MB1S BLACK FRONT BUMPER MFFS BLACK GRILLE MHBS FENDER FLARES MMCS MMGS BELT MOLDINGS MMJS MOLDED-IN-COLOR FENDER FLARES NAAS FEDERAL EMISSIONS NBAS UNDERGROUND CALIBRATION NBKS SELECTIVE CATALYTIC REDUCTION - WITH NDAS CATALYTIC CONVERTER NF5S 23 GALLON FUEL TANK QS3S Dover Gray RACS OPEN SCBS STEERING WHEEL SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS TADS RUN FLAT TIRES TBCS COMPACT SPARE TIRE TBMS TIRE CARRIER WINCH WJKS 15X6.0 STYLED STEEL WHEELS XBSS PICKUP BOX XFAS -35F PROTECTION ANTI-FREEZE YAAS BUILD TO U.S. MKT. SPECIFICATIONS Z1AS GVW/PAYLOAD RATING 1AAS U.S. DEALER RETAIL 161S ZONE 61-ATLANTA Link to comment Share on other sites More sharing options...
