JIMMYRIG Posted August 4 Share Posted August 4 Sup y’all A while back I did a zj disc converion with junkyard parts and never got around to hooking up my ebrake. It’s getting annoying. Are there cables out there on the market that are just plug and play from equalizer to backing plate? I’m tired of doing all this JIMMYRIGGING even though it’s in the name. Thanks Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 4 Share Posted August 4 There are. The best I’ve used so far is a pair of explorer cables. You need two of either the left or right sides. I don’t recall which ones but someone should have the answer. KJ liberty cables work but are far too long for an MJ. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 4 Share Posted August 4 Here is the one you need: XL2Z2A635AB It’s a 2001 explorer RHD right side. It should be about 51” which is about 3” longer than stock. They fit great on explorer or zj disk brake setups. Should fit the kj disk swaps too for those running an 8.25. Link to comment Share on other sites More sharing options...
JIMMYRIG Posted August 11 Author Share Posted August 11 Sweet, thank you. Will pick some up! Link to comment Share on other sites More sharing options...
