Dual diaphragm booster clearance
The photo appears to show clearance for the fuel linebetween both the booster and the inner fender/chassis.  If that is the case, there is no need to move the fuel line.
if you are really concerned about rubbing/vibration between the fuel line and the surrounding stuff, clip a pice of rubber hose over the fuel line to act as an insulator.
