JIMMYRIG Posted May 14 Share Posted May 14 I’ve been battling dash lights (including transfer case and ac control lights) going in and out. First it was a problem with fuse clips so I replaced. I’ve pulled the fuse box apart again and don’t see any issues with the connection. When I turn the headlight switch on I’m getting power to the fuse. Does that rule out the headlight switch or no? Link to comment Share on other sites More sharing options...
89 MJ Posted May 14 Share Posted May 14 What happens when you rotate the headlight knob? Link to comment Share on other sites More sharing options...
JIMMYRIG Posted May 14 Author Share Posted May 14 8 minutes ago, 89 MJ said: What happens when you rotate the headlight knob? Nothing Link to comment Share on other sites More sharing options...
89 MJ Posted May 14 Share Posted May 14 I would lean towards it being the headlight switch or a bad contact somewhere then. When you have the headlights on and you rotate the knob, that is your instrument light dimmer. Link to comment Share on other sites More sharing options...
JIMMYRIG Posted May 14 Author Share Posted May 14 So the power goes from the switch to the fuse and then back to the switch for the dimmer? Link to comment Share on other sites More sharing options...
JIMMYRIG Posted May 14 Author Share Posted May 14 Cuz I get no power to the fuse when the switch is off Link to comment Share on other sites More sharing options...
