87MJROB Posted January 31, 2025 Author Posted January 31, 2025 Probably going to be replacing the brake master cylinder hopefully that clears up the last of my issues on this. I still need a rear driveshaft that’s 2” longer than the xj one I have in it for now.
87MJROB Posted February 5, 2025 Author Posted February 5, 2025 I’m still having issues with my brakes. Pedal is soft and goes about 3/4 way to the floor before stopping when the engine is running. Only guess is still air somehow stuck in the system somewhere. It has brand new hard and soft lines, new rear wheel cylinder sand brake parts , new pads and rotors, good calipers, and a new master cylinder. So I took a break from that headache and started fitting some rear tj flares to the truck to make it look way better. Still have to do the passenger side.
87MJROB Posted February 15, 2025 Author Posted February 15, 2025 Today I changed the headlights out, replaced my driver seat buckle because it was broken, and installed a license plate light. I drove it to work this week and found out the rear shocks are too long and the windshield isn’t properly sealed so I have to get that fixed as well as figure out why my temperature gauge isn’t working.
87MJROB Posted March 5, 2025 Author Posted March 5, 2025 I’ve been driving it to work for a couple weeks now. Brakes still aren’t right but good enough to drive it. My other issue I have going on is my temperature gauge doesn’t read at all. It cycles when starting the Jeep and I’ve replaced both temp sensors on it and no change. Next when I have time I’ll try another gauge cluster and see if it’s the gauge that’s the problem. As far as I know all my grounds are good
87MJROB Posted March 16, 2025 Author Posted March 16, 2025 Weather has been warmer. I installed some azzy Comanche badges and some decals.
87MJROB Posted March 20, 2025 Author Posted March 20, 2025 Nothing new for now. Haven’t had much free time. I do still need to figure out why my temperature gauge doesn’t work, have a new rear driveshafts made to be 2” longer, and my brakes are still soft when running but work well enough to daily drive it.
87MJROB Posted April 15, 2025 Author Posted April 15, 2025 Been driving it still. Still issues to work out but I don’t have much free time now a days. I did finally install the wheels and tires I intended for this. Willys jk wheels and some ko2 315s
87MJROB Posted May 15, 2025 Author Posted May 15, 2025 Recently had to rebuild the front end due to terrible death wobble when I tried to adjust the alignment properly and found out all my balljoints were shot. I ended up replacing all the balljoints, axle shafts with cv style, and v8 zj tierod upgrade. found out most of my hub bolts were junk, had to weld nuts to two of them, so I replaced those as well.
87MJROB Posted May 15, 2025 Author Posted May 15, 2025 Current list of things I need to do: Figure out my temp gauge problem Repair the passenger side rocker and cab corner Replace my trac bar tierod end or change the whole trac bar entirely While I’m doing that I will add a small coil spacer to level out the truck some. I'm still running a xj rear driveshaft, it’s about 2” shorter than I’d like, so I need to get a proper length driveshaft built or modified.
87MJROB Posted August 11, 2025 Author Posted August 11, 2025 I’ve still been driving it a bit. I repaired the remaining rocker and cab corner. Replaced my trac bar tierod. I have not gotten a new driveshaft yet. Hopefully I can afford one this month. Still no working temp gauge. It’s not the cluster. I have no idea why it won’t work at this point. I did buy some new leaf packs second hand that I need time to install yet.
87MJROB Posted October 24, 2025 Author Posted October 24, 2025 Installed my new heavy load leaf packs awhile ago. It raised the truck atleast 2” Still have not figured out my temp gauge not working. still need a proper rear driveshaft and to raise the front end some more.
Smash6 Posted October 25, 2025 Posted October 25, 2025 It's really impressive that you went from an empty shell to a driving rig. Kudos. My favorite is "still need a driveshaft and my temp gauge doesn't work". haha. I laugh every time I read it. Well done!
87MJROB Posted November 2, 2025 Author Posted November 2, 2025 On 10/25/2025 at 7:45 AM, Smash6 said: It's really impressive that you went from an empty shell to a driving rig. Kudos. My favorite is "still need a driveshaft and my temp gauge doesn't work". haha. I laugh every time I read it. Well done! Thanks lol. Yeah I just haven’t had the free time or funds to deal with those things. Hopefully soon I can have a brand new shaft made the right length
87MJROB Posted November 2, 2025 Author Posted November 2, 2025 I had some used tubular upper and lower arms as well as some control arm drop brackets I got from a friend when I bought his 92 mj shell. So I installed all of those and a coil spacer to level out the truck and improve the ride. Definitely need all new shocks at some point to make it ride even better. I flexed it out for the first time in a ditch by my home. This is around 4” of lift and 35s
