87MJROB Posted January 31 Author Share Posted January 31 Probably going to be replacing the brake master cylinder hopefully that clears up the last of my issues on this. I still need a rear driveshaft that’s 2” longer than the xj one I have in it for now. Link to comment Share on other sites More sharing options...
87MJROB Posted February 5 Author Share Posted February 5 I’m still having issues with my brakes. Pedal is soft and goes about 3/4 way to the floor before stopping when the engine is running. Only guess is still air somehow stuck in the system somewhere. It has brand new hard and soft lines, new rear wheel cylinder sand brake parts , new pads and rotors, good calipers, and a new master cylinder. So I took a break from that headache and started fitting some rear tj flares to the truck to make it look way better. Still have to do the passenger side. Link to comment Share on other sites More sharing options...
87MJROB Posted February 15 Author Share Posted February 15 Today I changed the headlights out, replaced my driver seat buckle because it was broken, and installed a license plate light. I drove it to work this week and found out the rear shocks are too long and the windshield isn’t properly sealed so I have to get that fixed as well as figure out why my temperature gauge isn’t working. Link to comment Share on other sites More sharing options...
87MJROB Posted March 5 Author Share Posted March 5 I’ve been driving it to work for a couple weeks now. Brakes still aren’t right but good enough to drive it. My other issue I have going on is my temperature gauge doesn’t read at all. It cycles when starting the Jeep and I’ve replaced both temp sensors on it and no change. Next when I have time I’ll try another gauge cluster and see if it’s the gauge that’s the problem. As far as I know all my grounds are good Link to comment Share on other sites More sharing options...
87MJROB Posted March 16 Author Share Posted March 16 Weather has been warmer. I installed some azzy Comanche badges and some decals. Link to comment Share on other sites More sharing options...
87MJROB Posted March 20 Author Share Posted March 20 Nothing new for now. Haven’t had much free time. I do still need to figure out why my temperature gauge doesn’t work, have a new rear driveshafts made to be 2” longer, and my brakes are still soft when running but work well enough to daily drive it. Link to comment Share on other sites More sharing options...
