8 minutes ago, Dickinson County Comanche said:
I’m getting a nice multimeter to check for certain. I also have a 1989 electrical book so I’ll check in it as well
Thanks for this follow up.
So I looked in my book and it shows the same thing. I couldn’t get the multimeter I bought to work (genius who designed it made the probes about 1/16” long so they’re impossible to get any sort of accurate measurement from a plug) so I’m just going to look at replacing the coolant sensor, intake manifold gasket (pretty sure it’s leaking) and the O2 sensor and check back.
On the way back home, it acted up really bad again. Would immediately die when given any throttle from idle and it would only start when at WOT and it would studder for a split second after running. Then 30s later it was almost back to normal. I’m so confused.
