brucecooner Posted October 7, 2024 Share Posted October 7, 2024 I was disassembling my front drive shaft this weekend, and upon cleaning found a crack in one of the ears (?) next to the centering yoke. I think it got hit by an uncapped u-joint while I was hammering elsewhere. It's bunged up inside the ring, and a bit out of round as well. Bummer. The socket joint the ball rides in is pretty well grooved, but the ball wasn't really loose before I took the centering yoke apart. But I probably need a new driveshaft. I'd be okay getting a used one and replacing the joints (which I'd already got for this shaft). But if a new driveshaft is on the table, maybe I could consider an upgrade. I saw a placed called Tom's that sells them ready to go: https://4xshaft.com/products/xj-cherokee-front-drive-shaft I really want to lift this thing, someday, IF I can ever get enough other stuff sorted out, so a new shaft with extended splines in the slip might not be a bad idea. Or are aftermarket shafts not worth the expense unless you're lifting it half a foot and doing extreme wheeling? Anybody got a good recommendation, a place you had good luck dealing with? Or would you just get an old banger off of ebay and replace the joints? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted October 7, 2024 Share Posted October 7, 2024 Tom Woods makes great driveshafts as does Adams (I’ve run several of both with zero issues but slightly better service with Tom Woods). Both specialize in a lot of Jeep applications. A local driveline shop may also be an option if you have one close by Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted October 7, 2024 Share Posted October 7, 2024 I have a Tom Woods front drive shaft in my 2003 Landrover Discover II. Here's a fun fact: Those trucks left the factory with drive shafts that were greased but had no way to grease them, no fittings, a sort of sealed part. The problem is that the front drive shaft near the front connection is situated between 2 very hot catalytic converters that overtime does quite a number to the grease that's inside the driveshaft. And eventually it starts to squeal, and once it does, it is not long before that front shaft becomes a medieval weapon, breaks free, and goes straight through either the transmission or the transfer case. Don't believe it? There are pics to prove it! So I have a Tom Woods right now in it and seems to be doing just fine! Link to comment Share on other sites More sharing options...
