dash switch replacements?
I'm pretty sure I saw some recommendations a while back about this but thought it best to start again.
I want to replace a couple of switches on my dash that I'm not using (Power/Comfort-bypassed to Power and a Cherokee rear window washer (momentary) with a SPST for my transmission fluid cooler and a SPDT for a backup for my fans that are triggered by my Renix Engine Monitor just in case.
What switches will fit those holes, or will with minor modifications, and which ones look the most like OEM switches?
Thanks in advance.
The dash cutouts accommodate most standard Contura style switches. I went with OTRATTW switches. I believe the X series. I have a picture somewhere in my build thread of what they look like. They have a more retro look to them that felt period correct to me. Here is a link. Lots of options so you can get exactly what you want. They can also provide harnesses to keep everything clean.
https://www.otrattw.net/Contura-V-Series-Contura-X-and-XI/
6 hours ago, jamespwsullivan said:
Thanks for that.  I had looked at the OTRATTW products but it's not clear on a quick look if I can get a SPDT switch from them.  I'll call during work hours when I get a chance.
Still interested in others' thoughts on this.
They carry almost every option available. Keep in mind that most any contura styles switch will fit so there are truly tons of options out there.
