Track bar dimensions
Are they the same on all 4wd? The reason I ask is my front axle appears to be shifted to one side. Thinking track bar may be bent... Hard to check since fenders are not perfectly straight. Mine measures 30.5" from center of pass side hole to grease fitting. Grabbed another at the wrecking yard from an MJ The only difference-donor truck had vacuum disconnect while mine doesn't. Mounting bracket on pass. side looked different. This bar measures about 31.375". Anybody have a stock one laying out in the garage to measure?
Thanks
Tim
91 SB 4.0 AX15
Mine is brand new, just installed 31.5 and 33" respectively. Could be a tiny bit off as I had to measure it on the vehicle. All the 91's use the same trackbar. however the 90 and earlier have a different trackbar, that might be your problem. A lot of stuff changed on the Comanche between 90 and 92.
