Aussiemj Posted September 25, 2024 Share Posted September 25, 2024 Hi guys Had to fit a new rear housing to my ax15 as the mounts where broken. When I knock it a part a part fell out have no idea where it goes. Thanks Paul Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 25, 2024 Share Posted September 25, 2024 I had the same thing happen when I put mine back together I forgot to put this piece back in. Had to reopen the case to install it. That part sits in the tail housing on the end of the cluster gear shaft. It is called the oil filter although it acts more like a funnel to help lubricate the end of the shaft. Very important piece. It should definitely be put back in. Part #50 in the diagram Link to comment Share on other sites More sharing options...
Aussiemj Posted September 26, 2024 Author Share Posted September 26, 2024 Thank you I will finish the job now Link to comment Share on other sites More sharing options...
