Car Enthusiast Posted September 5, 2024 Share Posted September 5, 2024 Is there a part number or place to get stock size lower sway bar mounts? The ones that go on the axle? Previous owner put an aftermarket sway bar on there and it is too big for the stock sway bar end links to go back on Link to comment Share on other sites More sharing options...
Car Enthusiast Posted September 5, 2024 Author Share Posted September 5, 2024 Or is that stock bar links just bolted to the front end It's a 2wd Link to comment Share on other sites More sharing options...
The86manche Posted September 6, 2024 Share Posted September 6, 2024 There should be two almost L shaped brackets one on each side of the axle by the coil springs with a stud going through the side. The link should secure to that and then to the sway bar Link to comment Share on other sites More sharing options...
